Hoss 700 - have you tried angling the spray bars?
Scott S.
PA
Scott
has anyone tried angling the spray bars some so they spray forward a little?
would this help with using less water for the same cleaning?
how are you cleaning out your spray bar jets?
What set of glides are you using the most?
wheels vibrating driving you crazy yet? mine did tightened them up the other day.
did you change the hose from the head to the vac port on the tool? and if so can you post a pic of what you did.
Thanks Guys and Girls. .
Johnny
La-Z-Boy
Johnny
Haven't tried angling the jet bars. Ream out the holes occasionally by holding a steel brush strand with my Leatherman. Haven't noticed the wheels vibrating.
Reactions: Scott S.
Boca Raton
I angled the spray bars forward. It leaves the carpet drier than when spraying straight down. I don't know if it helps with cleaning or not. I always leave the square glides on. To much trouble to change and they work fine.
jwfoulk12
PA
Justin Foulk
I just added better site tubes. Ya cant see anything threw that semi transparent hose.
Boca Raton
it has a zerk fitting on the side. normally those take grease. Just checked the manual and it doesn't show or talk about the fitting anywhere.
