Edging tool
Yes. You can go straight down the edge or angle it away for thicker lines. Keep in mind, not all filtration can removed and it will come back.
of course I get mine in Canada but any supplier that carries pmf tools should have it or can order it for you. I think I paid aprox 325.00 cdn so it will probable cost you 250 maybe.
todg
Las Vegas
Michael Marcus
For $325 I'd go down and buy me a wet dry vac like 4 of them at that price...
Kellie Hiler
Kellie Hiler
I really like that tool...but how thick is the glide and does it prevent you from getting right up to the baseboard enough to notice it?
The glide is thick but you can pop it off with your hand if you need to. I vary between glide and no glide depending on th type of carpet and soiling. Awesome tool if you pretreat filtration lines and have some heat behind you.
Reactions: Kellie Hiler
Noidios
Anderson, SC
Russ Zinck
I have one of these, but the glide popped off and I lost it. Any tips on finding a new one? Recommendations on a glue to keep it in place (I have no intention of ever removing it again)?
Willy P
Vancouver
Willy P
Cousin Russ! Good to see more Zinck blood here! Caspar would be proud.
Reactions: Noidios
Kellie Hiler
Kellie Hiler
I would imagine it glides very nicely when turned sideways to get the other areas. It's normally a PITA to use it sideways without a glide.
