Thinking My Water Might be TOO Hot !!
Spurlington
On The Board
Spurlino
I was farting around the van and mixing up some shit with the aux hose connected to my solution line fitting (ATM). I did some more farting around then went back in to clean. I keyed the trigger and realized I forgot to flip the valve open. Went out not thinkin cause it was cold n snowy, I flipped the valve open and then here comes the pressurized steam whipping back n forth. Nice coating across my face then a couple of passes across my opposite of elbow.
Spurlington
On The Board
Spurlino
Im actually thinking of converting to propane heater. Ive had a brand new never used one sitting in the garage for the las 5 years. I was thinking of redirecting the lines from the heat exchanger into a large fresh water barrel on some type of circulation system to keep the water moderately warm before feeding it into the propane heater to give me the controlled heat I missed having back when I had a propane system.
Or keep it simple and do away with the exchanger. Although the warm feed would use less propane. Hmmmnn !!
Kellie Hiler
Kellie Hiler
I did that once and it whipped over my foot, by the time I realized it my foot was blistering and I've never removed a sneaker and sock so fast in my life!
Ever since then....I always hold that hose, even if I just started the TM.
Shane T
Waukesha, WI
Shane Tiegs
Happened to me once, water hit me in the stomach, skin came off immediately, some of the worst pain I've ever experienced. Now I won't have a open ended hose or one with on/off valve. It must have a trigger valve.
Reactions: Kellie Hiler
Charlie Lyman
Meridian, ID
Charlie Lyman
That looks painful.
I had a hose blow next to my foot once. Blistered my foot. Now that lead hose gets replaced every July.
rwcarpet
Youngstown, Ohio
Robert Hodge
That can be a HOT mofo! The new Pro1200 has a courtesy hose that is pretty hot, but is under a very low pressure. Won't go whipping around
Spurlington
On The Board
Spurlino
Arm clearing up .. I irritated it with the wanding motion .. polo shirt sleeve rubbing back n forth !!
Face Burn.JPG Face is peeling !!
Spurlington
On The Board
Spurlino
I wish I could borrow one .. try before I buy !!
I used a roto vac power wand (dual head) and Dri master floor tool .. couldnt get the hang of it !!
Definitely considering the 360
mirf
New jersey
David Mirfin
It seems like every time I want to use the sink there are dishes in it. Back to the truck I go.
