how effective is Harvard stain blaster red dye remover
wilpath
Harvard stain blaster red dye remover for taking out red stains completely, do you guys have any experience using this product, currently use vacaway red vanish but wanted to give this a try, thanks
Reactions: Mark Saiger
I use it
There are still stains that can struggle...
If someone has been messing around with a red stain it just seems to be tougher to get out..
Harvard will send you a free sample to try if you wish
You can contact @NeilM for that too
www.hcronline.com
It smells like ammonia just to let you know....
NeilM
Harvard Chemical Research
Hi - yes the stain blaster is our best red dye (synthetic) we make. It works with or without heat transfer method depending on how bad the stain is. Like Mark mentioned it does have a strong ammonia smell so open a window or two if possible in the room where the stain is being treated.
Jim Williams
Jim Williams
I have been using it for probably the last 8 years or so. It's good stuff. Many stains wont require heat transfer. Give it a try. You wont be disappointed.
