Bone Dry Encapsulation
Grand Rapids, MN
Bone Dry is a Harvard Chemical encap and they also have an Oxy Pro Encap. My brother really likes both products for encap work... I don't do as much encap work as he does.
But we use the Harvard Bone Dry a lot as our upholstery prespray.
I am hoping Neil from Harvard @NeilM will be along also to let us know if this is the same product.
NeilM
Atlanta, GA
Harvard Chemical Research
Yep this is our product and Janilink is one of our distributors. You should like the Bone Dry - this has been around a long time and never heard any negative feedback. Like Mark had mentioned earlier we also have an encapsulant fortified with Peroxide (Oxy Encap Pro) which is great for light colored carpet. The peroxide really brightens it up and works great on stains.
Reactions: Mark Saiger
kevinj6121
Calabash, NC
kevin
Thank you, certainly going to give it a try
Ne
Tried a gallon a few years ago. Worst encap shampoo I ever used. But if they reformulated it I can't comment.
Water thin with very little polymer in my opinion.
NeilM
Atlanta, GA
Hey Jimmy I can assure you their is plenty of polymer in our Bone Dry. Just an FYI - just because a product is water thin does not mean it is "watered down". Example: foam hand soap vs. regular hand soap. The foam soap is water thin but still has the same amount of active ingredients without the thickening agents. Most products with a real thick viscosity had to be "thickened" with additional thickening agents which bring no additional performance value.
