Judson TNT
Josh
Nevada
Josh
Good machine. Mine's been reliable. I do need to get my Little Giant fixed though.
Little Giants were created to heat baptism pools on Sundays. The constant on off and relighting we give them creates a lot of maintenance work, on Sunday...
Reactions: Kevin B
A.J.
Midwest
A.J. Hodges
I know what you're thinking man...... check out cobbs carpet care.
N GA
BradFenstermaker
I bought a used TNT a few yrs ago. I have enjoyed it. Because of its age but low hours I have replaced engine and cat pump. They are built to last IMO. Love the design.
Little Giant only takes about 30 mins tops about every 3 months to clean the burner ring. Most of the time its a 15 min job.
They are very hard to find if your searching used.
Just like any TM if you work them hard they will need some lite maintance/repairs occasionally.
I like that most anything that goes wrong I can fix myself. There is no fancy solenoid or exchangers to deal with.
Engine, Blower, Pump and there belts.
Ignition switch is the most complicated piece on them. LOL
I thought you had a Century400 Avenger210? When did you get a Judson?
What happened to the LG, freeze? One of my coils to an older #3 blew twice.. My friend did Silver solder it for me, but it's close to the burner ring so it heats up too much in my opinion...
I'm used to using LG heaters, so a Judson would be my choice.. With that in mind, if I did switch machines, I'd be looking at a SS870 or PCEverest650... So I wouldn't have a separate fuel source...
Reactions: cleanman71
Josh
Nevada
Josh
The power went out in the middle of the night and shut the heater off. Leaks now.
