- Oct 6, 2006
- 117,321
Tom you are the proverbial twin brother is my KTM mechanic in every sense of the word.
The end of the hose is far more dangerous than the peroxide. We handle the loose hose without even thinking about it. imagine what it could do if it caught your face. What about a leaky fuel system next to a propane flame. This job takes a little common sense.
Sally's sells me 1 gallon at $16.00 and it goes a long way. I bet if I bought by the case from them the price would come down a lot but as it is, for an extra 6 bucks a gallon (which should last a month at least) I don't have the hassle of handling it, dilution it, worrying about how it is stored or if it is getting to old to be effective.I use the 27% pool peroxide.. I keep 4 extra gallon jugs and split it when I get a new case. I don't add water to it until I grab a new gallon then I have fresh volume 44..
So, at $80 a case I have volume 44 for $10 per gallon..
I buy 35% from Brentagg chemical company. They also offer it in 50% but I'm used to the other. They deliver by the drum. It's the real deal. I have a special dolly it sits in and you can wheel it around easily. They deliver with a lift gate.What strength are you buying Gene?
You need to let your local fire marshal know that you have your drum and have a designated storage place. We do an annual Tier II EPA report (ingredients over 10,000 pounds) where we have a map of our location designating where our hazardous materials (including H2O2 25%) are stored. We have an explosive room where we store all of our solvents below a flash point of 100 degrees F and for solvents which we have alot of stock like d'limonene. In case of a fire we do not want firemen going into an area unprepared.
If it's working for you Gene, there's nobody here that can tell you your wrong but I would to someone that doesn't have your experience, be very careful about how you handle it. I learned the hard way not to put mixed product in the sealed container. Nearly had to change my underwear when that thing blewI keep it at an industrial plant. they have far worse stuff including a couple of containers of mercury.
your real fooking annoying man, are you a carpet cleaner or a English teacher.It's you're, and you should have a comma before "but".. Actually looks like horrible sentence structure..
When you say to as in also it should have two oo(habit of yours)..
Actually really like having you around here, I really doo.
Marty taught me how to spell..
How annoying can that be?
I've been using Aquasilk peroxide for a few years. Works great!
It's usually easy to locate and buy at local pool supply stores.
I'm pretty sure 1 gallon comes out at $20.
I haven't checked recently but I remember it being 28% and definitely better/stronger than beauty supply type peroxide.
That's awesome!! How much is a drum? I worked for Brenntag(as an employee)here and clean one of the managers carpet regularly.. Good to know!
