When I was little, my dad grew plants in the closet.
Charlie Lyman
Charlie Lyman
But he used pots and fluorescent lights.
This is a little different, I think:
What would you guys do with this?
I'm not one for mushrooms but the wife eats them.
What does the homeowner want?
Where is the moisture coming from?
Charlie Lyman
Charlie Lyman
I don't know. They just asked me to replace pad in the closet and clean. (Prop Mgmt)
Charlie Lyman
Charlie Lyman
Just remind them that if the conditions are right again the same thing will happen.
They need to figure out the moisture source and correct it.
I think the problem is gone. They just sent me the picture and a work order. This company usually takes care of business.
mirf
David Mirfin
You could put the plants back in and turn on the lights.
I doubt that fungus was just from water. Somebody had put something in that closet that caused it. Probably a wet box or cardboard.
At worse if it comes back just replace that peice of carpet.
Charlie Lyman
Charlie Lyman
I went to take care of this job today.
When I got there I used my hydrosensor and found that the pad was wet in a big area. I pulled back the carpet and the sub floor was pretty wet. It has been like this for a while, maybe even a month or more. I didn't want to put an air mover under the carpet and cause any bacteria or fungus to get airborn and make someone sick. So I called the prop manager and told them to get a restoration crew out there.
Reactions: Old Coastie
Charlie Lyman
Charlie Lyman
There was moisture readings in the wall above the baseboards too.
Goomer
Frank Mendo
The right shrooms can make all the difference on a bad day.
Uh, so they say.
Depending on certain factors, they can also make a good day bad and a bad day a whole lot friggin' worse.........at least for the next 6-12 hours that is.
Last time I indulged I spent 8 hours curled up in the fatal position drenched in my own sweat.
Ahhhhh.....The good old days..............:rockon:
Goomer
Frank Mendo
thats serious right there
Primal fear response to the visuals of the entire room rapidly turning red and melting every time I opened my eyes.
I think the whole 8th might have been a liiiitle to much.................:redface:
Zee
Fatal? :lol:
I guess it's just your spirit that participates here..
Sounds like Salvia.... I never tried anything like that but based on testimonials I read or seen: some scary stuff people go through and a lot of them say one time is all - never again. I guess it really gets their minds messed up for the trip and it sounds like a terrifying event.
