- Aug 19, 2013
- 7,008
- Name
- John Stewart
is there a simple test to determine if antifreeze is leaking into the HE with out taking it apart?
No not the vortex- Blueline bluewave-D My Vortex has been very reliable-- I wish I worked in the suburbs so that I could use it more often.
Slide- in; liquid-cooled engine- KabutaIs it a CDS-type system that uses the vehicles engine, or a slide in that has it's own liquid cooled engine?
It shouldn't. The radiator cap seals the system, won't let any coolant out until the internal pressure gets too high - like 12 psi or more.The overflow tank is lower then the Radiator cap and the overflow tank has a tube which hangs to near base of the machine--- I would think this would siphon antifreeze from radiator and overfill tank?
It shouldn't. The radiator cap seals the system...
