Spotted extractor
Derek
Derek
are you sure you need heat.?. otherwise those look to be good machines.
Those must be good to very good units as they have been around a long time and both sellers are credible, respected vendors (and advertisers so buy both.
When they arrive you'll soon figure out they are the same unit in different colors.
I have the Mytee/Sanitaire unit which is an OK machine.
I also have the 106" version of the EDIC Bravo and it kicks ass. With a 20 ft hose and a 1 1/2 hose and wand you could clean carpet with it.
jrizo1
I paid $35 for a nearly new spotter like the Gecko. It is worth every cent.
However, one SEVERE design flaw has you filling the water reservoir directly above the vacuum motor. The slightest slop and you douche the motor.
Here's an idea guaranteed to give you TM'ers dyspepsia: buy a Rug Doctor with upholstery tool for about $400. You get plenty of suction, a decently long hose for upholstery and even the instant ability to pull a reasonable job on carpets or rugs, or slurp the overspray around sofas. The little spotters can't do all that.
Just make sure the wife doesn't see you sneaking it out the door in the morning.
Reactions: Jimmy L
This is a very modern design done by the guy who designed the Sniper extractors.
It uses higher power 5.7" vac motors and built-in silencer:
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=85&products_id=1313
