FB7777
AgreedA tiny bit concerned about the load being off balance.
Also, they could mount the solution line to the front of the waste tank and enlarge the tank on the base to distribute the weight more evenly and increase the capacity
I'd skip,the rear shelves, where are you going to hang additional solution and vacuum lines? And why are the wheel wells wrapped in stainless? What purpose does that serve other than aesthetics?
. I had to install Air inflatable spring supports to get the truck to ride level, I would be concerned as Marty stated about overloading the front axle.
