Eracer OP machine...what did y'all think of it?
Derek
Derek
i just saw a video of the Zipper and Eracer faceoff....so what did everyone there think of the Eracer? worth the extra coin??
I was thinking I'd need roller blades to run it.
I couldn't push it any faster than my Cimex
Ill assume more one pass opportunities would take place due to the weight.
I think I'd get two Grumpy's.
It looked cool but it's so specialized, the Grumpy would probably serve you better.
Anthony said he has two and they burn through gym's with them. I would have liked to see it operate in wide open spaces for a better evaluation.
Maybe an electric unicycle? I'm not buying a Eracer to try it out though....
I also noticed the dry spots he hit with it....
Reactions: Derek
There was no question it made the appearance better and didn't have the wicking consequences that the whe side had the next day.
BUT IT AINT "CLEANING" anything.
Just washing and scrubbing the dirt to the bottom at a ver fast pace.
9000 is a bit steep I would say for a fast buffer.
Reactions: Jimmy L
The thing is massive. I can see using it on the first floor if a gang of stevedores could hoist it off the lowboy trailer it needs, but...
Zee
Nearly $9grand.... Someone please explain why, why, why, is it so much??
Can't help to think that it is so much because of the undoubtedly low quantity he can build and sell...it makes them be like those lame duck one of a kind Harleys for $100grand.
FFA
FFA
Its got a really good invertor and you can make 11k in a fraction of the time that you can with a orbot.
"The Eracer is the only machine in the industry that offers 3700 OPM's, 100 RPM's, 1850 TPM's. It oscillates side to side 1.125 inches, causing it to clean at 5 times the Orbot, which costing $4200.00 you would need to have 5 of them, plus hire 4 people to operate them to match it, plus even at that rate the Orbot is NOT designed to straight encap as it CAN NOT stripthe fibers clean to its pristine state."
rwcarpet
Robert Hodge
I'd still like to have seen a comparison on cut pile or loop pile, or even a Frieze twist. Encap/padding on CGD is great though.
Does that 9 Grand include mirrors and cup holders?
Space age technology? Can you have sex with it?
I bet That Joel Hoppe who hangs out on those nerd encap boards can't wait to use it on his garage floor.
Bet he can do his 9000 encap scampoo comparisons on that floor too!
HAhHahAhAaha!
Think pure thoughts you sicfooks..
Dustin are you a VLM super hero that can push a 200 pound machine over 260 square feet per minute?
