My Butler will not engage (some solutions) with Transmission safety switch Videos
Grand Rapids, MN
If your Butler will not engage, here are some potential things to check....
When push front panel engage system switch and the light is red in the center of switch (green would be ok and it would start) there is probably a safety switch that has engaged.
1) Check the float overflow switch in the waste tank just behind drivers seat...flop up and down, clean...and if that doesn't do it...Butler has a pig tail right there to unplug the wires coming out of the tank, into the wire harness right there to complete the electrical circuit....
2) if that is not it, could be the transmission switch under the van on the drivers side hanging from the transmission....that is adjustable, or again, hot wire the two wires there together with just a paper clip pushed in the wires....
3) could be the soft start switch up front by the drivers side headlight....hot wire 2 pink wires together if needed...
See the videos....every thing can be hot wired to make work until can get parts....
4) can try the power switch being exchanged with the speed control switch to see if just the switch itself...
Did the transmission switch videos yesterday laying on the ground outside as someone was having these problems yesterday...
La La Land
Hey..how long has it been since I sold Chris Lee that Genie....what a couple a years?.....and that little hillbilly peckerwood ain"t broke nuthin yet#
