The Ofer Certified "MUST HAVE" accessory for RV Brush Head owners.
This .49 pick is pretty much the ONLY way that you'll be able to get all the wads of hair that get embedded between the brushes
Works great along with your vacuum hose.
WK_hCPWnMXPnM_OVlcfEk3Mx1gJngOowErjIb3wHYwNivLXvoSHF_fzyY7M9FF3XbO87YeErgMVuifYNPA=w1769-h995-no.jpg
you should have seen it ten minutes earlier
I hit a tufted wool that two mutts live on..
Lordy... pulled a foot ball size wad of crud out of the brushes and the Devastator was 90% packed
Rug was so bright and fluffy, you'd think I pit washed it.
Why? Because they live outside of God's country? Have some compassion for the benighted!
By the way Ofer, the correct phrase is "Last time I done saw a tool like that..."
Some pretty big tools on the internet tonight, come to think of it.
Last time I saw one it was used to keep the critters outa the shitter. :winky:
San Francisco, CA
I just noticed (duh) that the jets on the Rotovac heads are all brass.
Do they not come in Stainless steel?
I was under the impression that stainless steel jets will last a lot longer.
rick imby
Montana
Rick
Last time I've seen a tool like that, it was used by a Russian dentist.
A must have if you're in the dentistry business in the Soviet Union:
Actually Ofer used the correct tense. If he had said " I seen" then it would have been incorrect. When he said "I've seen" that is correct English---
So we know who the really ignorant one is..
The proper tense Ofer used is past perfect if you want to know...
Reactions: ruff and Mikey P
