PC 650 hp has arrived!
BLewis
Lexington
Billy Lewis
The straps are rated at 1,000 lbs each with a brake limit of 3,500 lbs each, plus I am going to have a ring containment base fabricated for the bottom that will be bolted to the floor. I chose this because this box is only 12 ft and I needed the extra space. It will be OK I'm confident
Able 1
Wi
Keith
and look at how long they last and last and last.
I've seen many vortexes with 7-9000 hours and they just keep going and making money.
bigger most of the time is better.:rockon:
The Apex does pretty good for hours also..
Still perfect compression on all 3 cylinders!
Awsome me too. My mower runs great. Of course its a big motor, larger than most tm powerplants.
Ron, carpet cleaners lie...a lot. Running and performing well are two different things. :winky:
Able 1
Wi
Keith
There is a point of diminishing returns.. How much would it cost to replace one of those big motors? I like to rebuild truck mounts and the bigger motors seem to add complications to the project. I love the Kubota, and I can replace it for 3,500..
Fort Worth , Texas
Not arguing with you able you have a point but I could replace the engine in our Nissan us for about 4500 and they go about a million miles before they are done.
Btw the Kubota is a big motor. The hp is not high but dis placement and torque is up there.
Reactions: Able 1
BLewis
Lexington
Billy Lewis
Right out of the gate this morning received call for small water extraction job and 3 area rugs were soaked so I got to try out my rug shelf first thing this morning!
Able 1
Wi
Keith
What size motor does it need to run the blades, run the hydraulic pumps, and drag your ass around all day?
Mine just turns two pulleys. .. :winky:
BLewis
Lexington
Billy Lewis
Diggin the Spartans switch to LED lighting! Might have to add 1-2 more sets.
BLewis
Lexington
Billy Lewis
Had them install rinse tank on top of wheel well, leaves space for "soon to be added" chemical shelf and clears up more floor space which also allows more room for servicing equipment when needed.
Waiting on my 50 ft of 2.5 hose
She looks great Billy. You inspired me to move forward with my Spartan.
I ordered my chassis last week and sent a layout to Supreme yesterday but it likely will be a few months before I see it.
Meanwhile I'm enjoying yours vicariously. :cool:
Reactions: BLewis
Portland oregon
James Marsh
Did you get anything fabricated for the bottom? Or just strapped in
I originally had a stanless steel frame built for my Everest to Set-on. I told my supplier before hand. They said ok than when they say how high the machine was going sit they said no. Crap I was out a grand for the tank and a grand for the frame.
The only way the tank was going to fit was upright behind the hose reel. I used the stanless steel angle iron that was used to build my frame and bolted it around the bottom of the tank to the van. I than used 4 heavy duty eye hooks bolted with very large washers through the bottom of the van and two of the biggest racket straps I could find. I think they are 10,000 lbs a piece. Lots of weight on one side but I have not notice any problems.
Reactions: BLewis
