KILLER DEAL! On microfiber bonnets
Shane T
Waukesha, WI
Shane Tiegs
I've been using 17" Microbeast 2 and they just barely cover the 17" driver. Do you guys typically go a size larger?
encapman
St Petersburg, FL
Rick Gelinas
Hey Lyman,
I checked your order. You ordered the Blue ones, not the Scrub bonnets. I'll make the adjustment for you. :)
encapman
St Petersburg, FL
Rick Gelinas
Those are the same bonnets that we sent as samples. We hadn't heard any comments about their wear prior to sending the samples. Now that 2 customers have commented on premature bonnet wear, we've decided to move to a different bonnet manufacturer. We'll lose a lot of money over this, and frankly it's a little bit embarrassing that the bonnets aren't holding up as well we anticipated. But I want to try to do what's best for our customers, so discontinuing these bonnets is the only option I feel comfortable with.
encapman
St Petersburg, FL
Rick Gelinas
On a rotary machine you'll normally you want to run your bonnets at least 2 inches larger than your pad driver. Measure across your driver, then add at least 2 inches of surplus. That will give you and extra inch all the way around your pad driver. An extra 2 inches works perfect for a rotary machine. On an orbital machine you'd realistically want to increase the over-sizing even a bit further in order to give you a little extra wiggle room.
Fort Worth , Texas
2 inches could be a really big deal or deal breaker.
