Injection sprayer
realclean
Jesse Lowe
If you use an injection sprayer to apply prespray, how do you clear the line if you are using some type of rinsing agent?
On larger jobs I only pre-spray a small then I extract and then I go back to my injection pre-spray and with long hose run(130 ft) it takes a few minutes for the line to clear.
B
Bryan Thomson
The only time I'm highly concerned in flushing the lines is if I have been using an acidic rinse for carpet extraction and then switch over the pressure line to a hard surface tool to clean acid sensitive stone like marble, travertine or marble.
Otherwise....the minimal amount of acidic rinse really isn't going to be a problem.
If you do any natural stone cleaning.....I recommend you have "dedicated lines" for acid sensitive stone. Otherwise you better have DIP pads to re-polish the etch marks.
Trust me....I learned the hard way.
