Do REs need a safty switch?
F'n XL turns on as we plug it in today..takes aride across the bathroom and falls into the walk in shower stall..
Yippee!
Never had that happen but I have plugged in an Orbot and she was spinning. I'm sure I didn't do the counterweights any good. :errf:
Jim Nazarian
Jim Nazarian
Your fortunate tiles didn't break.
Happened once with the 360i, on handle was a little bent so when plugged in (different room) it twirled around & around like an ice skater across the room & slammed into the side of a bed.
Johnny
Johnny
Noooo! Don't dumb it down! Seems everything now is designed to avoid lawsuits by morons who aren't qualified to operate an electric toothbrush, at the expense of productivity and adventure.
Reactions: Russ T.
You have to squeeze the handle on mine.
Hey now, none of your fantasies here!
Mike, I put a lighted light switch box on my Duplex CRB, because the 'on' switch triggered by the handle being pulled out of vertical. It was a matter of time before it went walkabout... so to me it was a safety issue. Now the machine is dead until we are ready. Checking it before plugging in is a requirement.
jwfoulk12
Justin Foulk
My hoss would stick quite frequently. I still will plug the extension cord into the wall first and then plug the machine in as I am standing right by it. That being said I like not having one.
Shorty
Shorty Glanville
Down under, our Cimex machines only come with the trigger to start the rotation, same as the 360i's.
I stole an idea from you Yanks for my Cimex's & had an on/off switch installed.
After reading about the XL, I may do the same with my 360i.
Big pic is mine, other pic is standard Cimex.
