Now you're a neat freak
Did you on your big aluminum beast build?
I did originally. I just replaced the vac motors recently and forgot to specify the 2 in. The new ones work fine, but there is a noticeable difference in the air flow. I will order another pair and specify the 2 in. I may be building another one soon and am thinking of going with the 8.4's in parallel. Thet seem to all come with 2 inch openings. Vac's will be mounted with a similar manifold with no hoses. Just not sure if I am going to be able to run the pump with blowing the breakers
Ken692
Boston
Kenny
I think my pickup is getting $hity, I'll try to get a photo. I almost want to do a smoke test to see what's blown, I like to learn more how you guys hooked up the vacs to your equipment, for me photos help a ton.
Ken692
Boston
Kenny
$75 with shipping looks like they changed it to brass fittings
Goomer
Bronx, New York
Frank Mendo
Your Oreck is great for touch ups like this.
Scrub in a good encap juice with a red pad and finish up with an absorbent microfiber combo pad and you will be in and out in 20 minutes.
Also less risk of it wicking a second time.
Reactions: Jimmy L and Willy P
Ken692
Boston
Kenny
That's funny, there was a wick stain next day, guy was like I know your back but do this first, what's a good endcap, sorry I'm on the learning curve, I like to try some
Goomer
Bronx, New York
Frank Mendo
Releasit seems to be the most popular......
http://www.excellent-supply.com/CARPET-CLEANING-CHEMICALS_c_65.html
Can't go wrong with anything from Vacaway either........
https://store.vacaway.com/very-low-moisture-vlm-c30.aspx
Microfiber combo scrub pads 13"............
http://www.directmopsales.com/MICROFIBERSCRUBCARPETBONNETS_s/108.htm
Anyone only using an Oreck to agitate is not taking full advantage of what those little gems can do.
Great entry level tool to the wonders of various VLM encapsulation cleaning techniques if you have not tried them before.
You will be surprised at how effective it can be, regardless if you can figure out where the dirt goes, or not............:biggrin:
Ken692
Boston
Kenny
It's like your reading my mind! I was sitting here trying to get my head around just using pads over HWE
Ken692
Boston
Kenny
I'm very interested in this vlm.
Took me 4 hours to fix this liquor store
Ken692
Boston
Kenny
Thank you Barry.
I just ordered a sample pack of cleaning solutions and I'm just looking into vlm type cleaning.
I'll try to report my results
Goomer
Bronx, New York
Frank Mendo
What do you think of hot knife
Both products have been around a while and are considered top-shelf juices.
Don't spend too much time deciding which one, just get a jug of either in your paws ASAP and start playing with it.
Any product that passes the rigorous testing and scrutiny involved in obtaining the Sutley Seal Of Approval must be good stuff.
Reactions: Ken692 and hogjowl
