Citrasolv question
FB7777
we use Flex powder with citrasolv
Not all that pleased with the fragrance compared to the combination of Liquid version of Flex and citrasolv booster
We add a few ounces of citrasolv when we use the powder version of Flex to improve the fragrance but still not as pleasant as the liquid version
Any ideas why the two versions differ ?
The powder version fragrance reminds me of the less expensive D-Limonene booster versions on the market
Less expensive versions of Citrus solvents are usually diluted with solvents that don't smell as good.
In our PowerMax powder we still only use actual d=Limonene as our solvent.
We do add a fragrance which we think improves the customer perception during the cleaning.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=65&products_id=1150
Reactions: Jimmy L
J Scott W
Jeffrey Scott Warrington
Powders can only hold a certain amount of liquid. As one gets closer to that limit, it become more likely that the powder will get clump, lumpy, hard as a brick or however you want to describe it. THios happens as the powder absorbs additional moisture from the air.
The Flex Powder has somewhat less d'limonene becasue of the limitations of how much liquid you can put into a powder and keep it from clumping. There are other powder cleaning agents added to compnesate, but the fragrance will be a little different.
FB7777
Thanks for the explanation Scott
We've simply taken to boosting the powder with Citrasolv mostly for fragrance
Having seen any adverse effect such as gelling . It separates but that's an easy fix with a shake of the HF
I hated to have to stop using PM, but the smell was annoying.
Powermax works ok but I never got a citrus scent from it. It smelled more like a place that had a serious roach infestation.
but maybe I just got a buckets without dlime..............I heard he has issues with consistency
not to mention the shameless link dropping bs
I love the non stench of Flex Powder..
but adding a liquid deelimo certainly helps on the grease pits.
A powder'd solvent can only do so much.
Reactions: J Scott W
Loren Egland
Loren Egland
Seems like most on this board use powder prespray and liquid through their equipment.
I do just the opposite. Maybe has something to do with equipment. My 8 gallon mix tank fills with hot water with the turn of a lever so powder is an easy mix, especially so due to the whole top being a lid. No in line sprayer plugging using a liquid prespray. Just pour it in.
FB7777
Stopped using powder rinses, found them clogging my lines filters and fittings
Use both powder and liquid in HF sprayers
No clogging issues, perhaps cause I use different chems through them
FB7777
It's really not all that bad. It's no better and no worse than anything else. I just got tired of the smell.
Stop being a grumpy Yankee.
" no better and no worse"
In Yankee country we refer to that as " average"
I prefer above average everything
Tom Forsythe
Fragrances including d'limonene diminish more with time in powders than liquids. The cleaning action of the d'limonene is not diminished. Add 1 ounce of Citrus Solv to Flex Powder at 1 to 32 adds several times more d'limonene to the ready to use brew. We only use Food Grade d'limonene and pay a premium for the best.
My guys like cobbs it's not always the end all for everything but that's why we carry firestorm or flex for real nasties.
I dont think doing every carpet with the highest ph is always good.
