Jump the Shark with Bawb Vawter
My vacuum store guy won't stock Dyson. Claims they're a pos. Propietary parts and so on when they break down. Mind you he doesn't carry Shark vacs either. Only quality stuff like Miele, electrolux, panasonic, sanitaire, etc.
His sales would go up to the soccer moms if he sold dyson.
Reactions: hogjowl
San Francisco, CA.
He doesn't like those vac because there's no "Come Back". He only promotes Vacs with high profit and hooks the customer on "The Comeback": with the need for bags and belts.
Like a heroin dealer-- the 1st hit might be free-- but hes got you on the comeback.
Reactions: Zee
My biggest problem with the shark is the mess it makes when you have to dump it. With my Panasonic, I just pull out the bag and slip another one in. Clean and easy.
La La Land
I was thinkin about a Dyson cordless......
I recently bought a Dewalt cordless 40 volt weed Wacker and it was way better than any gas wacker you can buy.
Reactions: glenboy
Put this on my Blog today
As a "vacuuming professional" I often get asked to recommend THE BEST vacuum . My stock answer is "The one you enjoy using the most".
That being said I do like Sharks a lot. Keep in mind that they (and Dyson) are like Bic lighters, once their break, you just buy a new one as no vacuum repair shop will work on them. The Shark's have just as much suction and cleaning action as the Dyson's and can be up to a 1/4 of the price. Unfortunately, Shark comes out with a new model every six weeks and they keep getting bigger and more complicated.
I highly recommend this older, cheaper model:
https://www.amazon.com/SharkN.../dp/B007L5K6JW/ref=sr_1_2...
If you don't want to contribute to the land fill and desire a vacuum that will last a life time, and you don't mind a little work out while you clean than either a Kirby (don't buy new, you can find like new models on Craig's List for well under $500 in bigger cities) or a Royal
"All Metal Upright" which is basically the same vacuum minus the transmission for the wheels, so you'll work even harder on some carpet types.
https://www.amazon.com/Royal-Commercial.../dp/B005IBNWEW
Keep in mind both of these DO NOT have on board attachments and fitting a hose and tools is a real hassle, so I recommend this handy classic for cleaning your upholstery, drapes, hard floors and autos with..
http://www.cleanfreak.com/.../hoover-portapower-canister...
Both of these vacuums, unlike the Shark require a paper bag to contain the soil so be sure you have it in the budget to replace the bag(usually around $1.00 each on Amazon or $3.00 at a local hardware or vacuum shop) about once a month on average. If you have a 1000 plus feet of carpet, shedding dogs and a dusty yard and active kids, you may need to replace every two times you clean the whole house.
Belts will need to be replaced about every 20 times as well as they stretch out and the brush roll will not spin on pile carpet. $3.00 or so online.
Sharks use a cogged belt and will last it's life time, needs no bags and at $128 starts making a lot of sense.
There is a foam filter or two in the Shark that you'll want to wash every month or so.. Run it under your faucet and squeeze it repetitively until the water runs clear, set in the sun to dry. Keep an eye on the filter INSIDE the dust cup as it can clog as well. Just brush it to clear any blockage.
Doug Rice
I use that mess to sell my quality cleaning. I always dump the vac in their kitchen trash if it's not overflowing. I want them to see what I take out before I light up the truckmount and explain to them why I remove as much dry soil as I can. It's especially fun when the have a Dyson because they NEVER vacuum the stairs.
La La Land
The $400 Dyson cordless sucked a half bucket of sand in one pass then they emptied the sand back on the carpet and added a couple dozen
marbles in the sand....
One pass forward and it was all gone
The whole thing is only 4 1/2 lbs...
I used to laugh at cordless.....but the weed Wacker made me a believer....
Probably photo shopped
Ne
No Mikey my actual quote on the question that "Clients" ask me about what is the best vacuum is..............The BEST vacuum is the one that gets USED.
Reactions: Bruce Humphrey
Big Jim
El Dorado Hills California
James Milne
You're welcome Jim
Make sure to turn off the beater bar when edging or uph cleaning
The tiny motor will live a short life
Thanks again for pointing that out. I do use a Dyson 65 animal at home that I like for maneuverability (the ball) and the attachments. I prefer dirt cups to bags; customer (and myself) can actually see what is being removed and no bag cost.
Prattville, Alabama
Amen!
Although the Dysons have gotten worse as the years have gone by.
