Working with some peroxide for Yellow & Tannin Stain removal
Been getting a few contacts for removing tannin, or yellow or similar stains....
Just had a video and photo opportunity yesterday....
This video has music too Marty :)
Screw what Marty says. I'm saying the music is annoying as Marty's mom. Music Free is my vote.
As for the magic...is that a peroxide/ammonia mix? Or is it just a stronger peroxide than the yellow out? Thanks for the video. I understood half of what you were texting me yesterday about this product
Reactions: Mark Saiger
The Just Like Magic is stronger peroxide than the Yellow out.
The Just Like Magic has a few other ingredients in the mix compared to the Yellow out, but no ammonia involved in either.
Be patient for then entire removal if you is seeing something....misted a little more on after the cleaning too :)
I
For water stains I find a cellusosic browning treatment works as well with less risk.
I've only used one gallon of browning treatment the entire time I've been in business. Maybe I should get some more
Chemspec browning treatment is glacial acetic acid with sodium metabisulphite (a mild reducing agent) It will reduce the intensity of a water stain on carpets or upholstery without affecting the dye structure. Do not mix or spray over strong oxidizers like peroxide. I use it often as a souring agent for cleaning delicate upholstery.
C
Chris Howell
Looks like poly carpet (matted/flattened traffic lane). I should HOPE it would come out! Heck, you can use bleach to remove a stain on poly carpet! :hopeless:
What was the stain from?
This was a water stain....had some other properties in the water, but overflow of drain and washing machine I believe or rinse tub...
