C
CPS Dave
Do you use a portable? If so, do you have any questions? Or maybe have any tips to share? I love porty talk, so many variables!
Haha! We all started there didn't we?Hate HATE HATE portables!
Hacks! Semi-pro at best. Scourge of the industry!
More?![]()
...but not even a mention for Yours Truly?Yes. Its a natural progression...unless a U R A dipshit and get stuck there like Willy, Ron & Frank.
Morons!![]()
Portables are Mexican truck mounts aren't they?Yes. Its a natural progression...unless a U R A dipshit and get stuck there like Willy, Ron & Frank.
Morons!![]()
Too much respect for ya!...but not even a mention for Yours Truly?
I get irritated with all the sand I see that gets into my Gate Valve.... I literally need to take it apart every job to clean out where it seals.... I like the way US Products has the hose and cap on the Flood King...
Vacuums in parallel stacks deliver the most CFM's...
This is the wand we like for portable systems: 12" Bentley Head, 2 jets, Bentley Assist Handle, SS Glide, or opt. PTFE Glide:There is a 500 psi version. I have used the 1200 psi version on several occasions and no issues. It's in our local supplier's rental equipment and he tells me it's his most reliable machine. Not a knock off so maybe you haven't had a chance to actually use it or see it.We like a high GPM pump that sprays @ 500 PSI with a full 2 gal./minute flow.
We use the 500 PSI setting for TM wands as well as TurboHybrid.
Our experience with higher PSI pump systems is that they overheat quickly when extracting carpet,
causing seal failure.
I didn't say the Nautilus portable innovated anything. They just built a very solid portable that I like. period.So WHO is doing the innovation . . .
The problem with machines having 500 psi@2gpm is that along with 2 proper 3-stage vac motors, you will need a 20 amp circuit for 1 power cord. Not always available. My pumptec m58 gives me 500 psi at 1.5 gpm at 2.74 amps. When both vac motors are running and vac hose is connected to the wand, each vac motor drops to aprox 12.5 amps, keeping me at that 15 amp range.
This is like trying to gain an interest in a conversation between women discussing makeup application.
Yep, 2 cords. 1 takes aprox 12-13 amps, the other approaching 15. I use an separate inline heater with it' own cord. I normally use a 4 flow with it but can go to a 5 maintaining 500 psi with the trigger open. 4 works best with heater. I have enough amperage left on the 1 cord to put an apo if I want but with 20 gal recovery, I don't really need it.That's with your Aluminum beast?
I have been looking at those. Have you actually tested the amp draw with a clamp meter, running all the components?New 6.6" Lamb tapered fan vac motors are much more efficient . . .
allowing the same 15+ amp draw with the new Cat Pump & motor.
It can be done and you can get great results as you have proved. Does take a lot more work. When you are ready for the tm, take a good look at what your needs are and go from there. I use propane heat but it is getting harder to get every year. I will probably be going the way of slide in with heat exchangers in the future.I personally get happy thinking about when the day comes to purchase a truckmount my choice would be the Butler ( lease deal) 3 year...or.... and really leaning toward A JUDSON MAX C.A. propane Engine and little giant in a Nissan NV cargo...however in the meantime Rotovac ranger 24--1200 ..15 fresh duel 3 stage and a Mytee hog booster when needed (love that thing )....adapters for dryer/stove , and Be-9000 generator ...I love this business and you guys have been a great help. Oh and it's way more work on the porty set up ,but it doesn't bother me I just enjoy it..also have a grill propane tank that runs a ez tankless 101 will auto fill the 24 holding tank with 120 degree water ( when needed) then the Mytee heater will get it so hot when done right will take your flesh off ez tankless fits on a dolly...with a seal-A-door the porch works
Thanks.... like most I started on a serious budget... and never stop studying and learning and that's how I'm spending all my free time... first day off I've had in awhile but this was a career change for me and I take it very very serious and at the same time I LOVE IT ... I'm getting excellent results I don't post often but when I do....lol.....anyway one day at a time ... but after all the research so far I keep going back to the Judson... and here in Arkansas no shortage of propaneIt can be done and you can get great results as you have proved. Does take a lot more work. When you are ready for the tm, take a good look at what your needs are and go from there. I use propane heat but it is getting harder to get every year. I will probably be going the way of slide in with heat exchangers in the future.
