Jet sizes for pmf wand
WillH
Albany,Ny
Capital region carpet cleaning
Hi everyone I have a few questions about jet sizes for my pmf 4 jet wand. What is the best size to use ? I'm using a prochem blazer xl with 60 gallon tanks. The reason I ask is that I'm going through a lot of water it seem but I'm not sure. How many square feet should I be able to clean with the 60 gallons of water? Right now I'm using the jets that came with the wand.
Maximum would be .15. that will give you a 6 flow. 11015. Some wands may use 8015 but may get streaking with that. Sometimes it helps to put 11015 in the middle and 8015 on the ends to avoid over spray. If you are going through to much water, check that the thermal relief valve in the water box is working and make sure your temp bypass is adjusted and working
.1 or 1.5 flow for each jet.
I would guess you could clean up to two normal homes with 60 gallons
Do you own a Rotary Extractor?
Benton KY USA
Will, if you are new to this start with lower flow and ease up after you've determined the proper balance for your system and abilities.
Reactions: Erik
WillH
Albany,Ny
My wand came with 8001 jets and I've been cleaning with 400 psi
you may want to up it until you get an RE.
try 8 if you want, you can always add an extra ounce of pre spray to make up for lack of heat.
What are you scrubbing with prior to wanding?
dgardner
Phoenix, AZ
Dan Gardner
Will, if your jets have many hours on them, especially if they're brass, they could be worn and flowing a lot more water than the size would suggest. Jets are maintenance items and need to be replaced periodically.
If you think you're using too much water that could be a possibility.
When you do get new jets get stainless.
60 gallons? You might be able to finish one 500-600 sq/ft if its not too dirty.
100 gallon tank is the safest bet. Its bigger and will take up more space but 60 just won't get you far.
Reactions: hogjowl
Keep the 60gallon tank. If you get a bigger tank you'll lose suction, due to the size of the blower on that blazer
And as for the tank filling up too fast. Turn your water supply on, and listen for a dripping sound in your waste tank. If you hear that, it's the sensor in your water box that's filling up your tank too fast
I just changed my 185 degree temp relief in water box on 405, my guy were filling up every 3 room, now they can easily do two house at 10 flow before draining.
We pre spray and scrub first with helps the rinse side out a lot.
Dallas, Texas USA
Increasing the jet size DOES NOT reduce heat from a heat exchanger.
The more water you run thru a HX, the more BTU are developed.
Temps will not be as hot,
but more total heat is delivered to the carpet.
I'll need to read that Texas logic a few times in hope that it sets in.
Let me see if I can relate it to something less complicated.
Marty is an idiot. That is a fact.
Increasing his knowledge on this forum DOES NOT make him any smarter.
The more knowledge you enter into his brain, the more his smarts are developed.
He will not be any wiser,
but more time is wasted online?
is that correct?
Reactions: Bob Pruitt
In every cleaning system, you only have so many btu's available to heat your water. Kerosene is the hottest and unassisted coolant exchangers is the coolest. Engine coolant and exhaust/blower combinations are in the middle. Your blazer uses the engine exhaust and blower exhaust to heat your water. Your 18hp motor and #3 blower can only provide so much heat and if you exceed that capacity your temperatures will drop at the wand. The manufacturer recommends a 3 flow for best performance. The problem with a 3 or 4 flow is that it takes a long time for the hot solution to exit your hoses and wand and come up to maximum temperature. Every time you let off the trigger, the solution is cooling down in your hoses. I have found a 6 flow works best but if you have the trigger on continuously, you will experience a cooling of the solution. I would start in the middle of a room and clean to one side, then dry vac back to the center and repeat on the other side. A 6 flow will come up to temperature faster than a 3 or 4 flow but it is not sustainable for too long. Modify your cleaning techniques to reflect this.
