Favorite Chemical Combo?
Ryan
Hey guys I was wondering what your favorite combination of prespray / rinse was for residential.
I'm trying to keep it simple and use one chemical.
I highly recommend having three pre spray choices
  1. Silver Bullet High pH Nuke Juice
  2. Every day, fresh water rinseable 9 ish pH powder
  3. Neutral pH wool and baby safe
And the ability to use three rinses
  1. Soft water
  2. Alkaline
  3. Acid.
Just the way it is.
Ryan
  1. Soft water
  2. Alkaline
  3. Acid.
Just the way it is.
Just what I wanted to hear!
Thank you so much, I'll do some research on specific products for each type.
I understand when to use the three different presprays,
could you explain when to use the three different rinses?
Thanks!
Reactions: Mark Saiger
Thanks!
Acid for the nuke prespray
Acid for wools
Acid for past residues
Alkaline for restaurants and hellholes
Water for well maintained jobs where you used 2&3.
Water where children crawl around
Water on chem sensitive people
Reactions: Helix cleaning llc
Here's a great question
IF you could only have one cleaning agent on the truck, what would it be?
I would have to go with Procyon.
You can always crank up the heat and agitation
Or reject shitholes.
I agree 100 percent. You can use the Procyon plus powder as your prespray and your Rinse. Combined with a brush pro or rotovac brush head, you are good to go.
