Lube me up so I can reach my APEX...
EDS
Canada
Ed
Need help locating and help filling my blower lube levels (part of my checklist).
I have a 2004 apex. Not sure where to fill and drain...
Thank you in advance...
Able 1
Wi
Keith
Take your sight glasses off and clean them up while your at it..
Post a picture of the lobes of your blower..
Reactions: dealtimeman
EDS
Canada
Ed
To take the blows out would it be diffuclt? Undue bolts from the the black casing and then disconnect from a coupler???
Able 1
Wi
Keith
That thing is HEAVY!! There are 4 bolts under it also 9/16 I believe.. I rigged up a winch to pick mine up..
Reactions: EDS
EDS
Canada
Ed
I think I popped something taking those caps off...and of course the busted knuckle.
EDS
Canada
Ed
I bought 2 qaurts. How much does it take? Pasenger side took 3/4 of a quart and sight glass on drivers side is fxcked up and I can't see when is enough. Don't want too over fill
Able 1
Wi
Keith
It's probably about the same on both sides.. Fill it slow and make sure you are on level ground. Clean the sight glasses with a good degreaser and Qtips if you have to.. You NEED to watch the sight glasses to know how full it is.
Reactions: EDS
Able 1
Wi
Keith
If you over fill it, use a turkey baster and some hose to suck out the extra..
Reactions: EDS
EDS
Canada
Ed
damn me....definitely was not on level ground. And my one sight glass is cracked so I can't see shxt...
EDS
Canada
Ed
Will order new sight glass from DG distributor.
Another question, when I am not under a load my vac shows 3-4 hg... any idea why?
Able 1
Wi
Keith
Well... As long as you have the good sight glass side right, park it on a hill and change the sides of the "good" sight glass.. :biggrin:
Able 1
Wi
Keith
By "any load" do you mean without any vacuum hoses attached?
wilpath
my sight glass is also messed up, took it out tried to clean it, nothing , where is a good place to order one
