E
EDS
I don't believe that the persons using it now are using the proper dilutions. If the are charging $99 in my market for 5 areas or offering groups for $39 dollars how can it be anything other then a bait and switch? And if they bait and switch how can they be trusted to use the proper dilution ratio's when they clearly have a history of dishonestly? they can't.I don't believe you give it away. And I don't believe you use the proper dilutions either.
If you have not caught on by now, I am trying to be distinguishable. This is one area that I can showcase how I am exceptional (special Ed). I don't have the client list that Meg has to raise my prices substantially. That being said, if I can offer value to the customer at minimal cost (not selling protector anyway) and try and up-sell SERVICES rather then a PRODUCT with little profit margins compared to my labour then why not?
I can kill two seals with one stone. Not only am I doing something NO one else does but I'm also keeping the door open for the upsell of a SERVICE which MAY be closed if I start hawking everything and anything to the customer. I hate it when salesman do that.
Not to mention it will make my job easier the next time I clean. I want this product to work so I will use as directed...however that is kinda confusing. 3M website says 1600sqft of coverage yet packaging data says 1000...https://www.sycorp.ca/chemicals/carpet-protectors/scotchgard-carpet-and-fabric-protector/
Read the documents section for the shift shxt...(see I'm critical like you Jimmy)
I based my calculations on the lowest end of the spectrum...if it is 1600 sqft I break even.
And the advertising potential is huge...
PS...hopefully I did not offend you when I noticed you under the bridge...
