Bane-Clene cleaning detergents are way underrated!
D
dgardner
However with 220 volts in Australia could you put twice the powered electric motor on the Bane?
I don't think so. I'm not an expert in international voltage standards, but I'm pretty sure that while the voltage is 230 in Australia, the typical ampacity of a branch circuit is only 10 amps. So we have 120V at 20A and they have 230V at 10A - the available power (watts) is essentially the same.
Someone from down there correct me if I'm wrong about the 10A circuits.
The plumbing on a Bane wouldn't function well with higher power. We tried. Turbulence in the recovery tank along with NO filter or float shut off guarantee water an debris through the blower.
FB7777
Yep
I added propane heat
Looked at inline vac boosters
Waste of time, just use a high quality portable if you don't want to go fuel fired
Reactions: steve_64
Bob Savage
Bob Savage
The Bane is a bane:
bane
bān/
noun
  1. a cause of great distress or annoyance.
    "the bane of the carpet cleaner is the over-sized, under-powered iron lung"
    synonyms: scourge, plague, curse, blight, pest, nuisance, headache, nightmare, trial, hardship, cross to bear, burden, thorn in one's flesh/side, bitter pill, affliction, trouble, misery, woe, tribulation, misfortune, pain
    "scurvy was the bane of these seafarers"
    • archaic
      something, typically poison, that causes death.
However, they are a loyal bunch.
Reactions: FB7777
FB7777
Lol Bob
I remember G Tom Tsao posting that definition back in the ICS days
Evan came down hard with a reprimand with his typical paid advertising protectionism
I think Tom left the industry and started selling some kind of lighting online
You can probably find Evan selling lighting at a local Home Depot
rick imby
Rick
I guess you had not discovered Devastators at that point...
