icleancarpetz
- Mar 7, 2015
- 1,709
- Name
- Rafael Samson
X3.....
SS then.... It's got all the hallmarks of what you are looking for.....Ergonomic and light weight is important and a must as well as the ability to handle delicate fabric.
Go back and read Jim Pemberton's post above.......Ergonomic and light weight is important and a must as well as the ability to handle delicate fabric.
PMF you can do better detail work.
I like the 'feel' of the not-so-Mytee...... It's just that fact, it's a P O S....... They should sell them @ Walmart...... That's how well they are built.... It's turned me off of ANY not-so-Mytee products......The Mytee is great ergo wise.
But they need to sell them by the dozen.
If yours has the flat spray bar, it can "iron" a synthetic velvet flat if you leave it in one place when using it with a truck mount.
One of the nice features of the Clear Head SS Tool is the fact that you don't have to continually use the trigger.
There is a sliding piece on the underside of the tool that blocks the trigger so it will continue to spray.
Make the adjustments of flow with the brass flow control and clean all day.
Very light...pretty much the perfect upholstery tool.
At Mikey's Fest St. Pete... I locked it and cleaned piece after piece that way... I like it. Most people don't even know that feature is available.In all honestly, the trigger lock feature is a great "idea" but I haven't used it or had a big enough piece to warrant locking the trigger.. I'm sure others feel the same way too...
We were cleaning outside Nate so I see your point. I guess I like that it's an option of not having to hold the trigger the entire time.you unlock it after doing a wet pass then dry pass before cleaning the next piece
