Anyone run Amsoil in their truck mount?
Swani
I would really like to prolong the life of the engine in my 427. Anyone runs amsoil in their truck mount?
Our choice is Kohler's 20W50 motor oil.
Not a synthetic, but has an additive package with more zinc,
that is better than an automotive spec oil with decreased additive package,
for air-cooled engines.
Swani
This is what I was thinking of getting.
http://www.amsoil.com/shop/by-produ...mula-4-stroke-10w-30-sae-30-small-engine-oil/
Goomer
Frank Mendo
I'm sure it's good stuff, but if your going to use Amsoil, might as well go with their premium syn air-cooled racing or premium syn motorcycle oils that specifically state a robust Zinc additive package.
Second best thing you can do it make sure the unit's airflow and supply of fresh air is optimized.
Reactions: Living The Dream
Swani
I'll definitely check into it! Thanks!
I think the 10W30 is too thin,
and the Amsoil 10W30 meets API SJ, SH, SG specs,
which means reduced zinc additive package.
jack zerkie
A local guy here told me that it's not just the oil, but their own oil filters that make them special . They are made just with their specs. and that combo gives that amsoil sales . jz.
KevinD
Kevin Dumas
I switched my 38hp Kohler over to the Kohler 20W50 oil several oil changes ago.
Less lifter noise, less oil consumption, less gasket leakage than when I was running Mobile 1 10W30 synthetic.
Reactions: Larry Cobb
Kevin is correct . . .
The Kohler 20W50 is a "racing oil package" with more additives.
Kohler switched from 10W30 to 20W50 in their "big block" larger HP engines.
We originally used straight 30W, and our engines performed well.
Some customers who used 10W30 had some issues with piston & ring scuffing.
We have it at a good price ($4.95) for a "top brand racing oil":
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=68&products_id=4054
Paul B
Paul Beardsley
I use the Amsoil small engine oil and their oil filters. But have to agree no matter what oil regular maintenance is key.
