Laser measure, Bluetooth,Invoices
Ann Arbor
Steve Lawrence
Has anyone here used their laser measurer with bluetooth and an Ipad or tablet to create invoices easily on the spot?
What equipment and application are you using? How do you like it?
Thanks,
Steve
Heart of Dixie
Steve, I use Zoho and have all our services already defined and described, with prices.
So carpet, residential.
Carpet, commercial
Tile, ceramic
And so forth.
Prices are per unit, be it square feet, room or what have you. Then, i just select the item, enter the number of units and percentage of discount (if given) and it generates the whole invoice.
Other software does the same thing.
Measuring is by wheel, it is fast and I can adjust for eccentric shapes. I keep a running tab on the iPhone calculator and then enter the total as described above.
A bluetoothed laser sounds neat, but wouldn't be any easier for me.
Ymmv.
jwfoulk12
PA
Justin Foulk
Carpet, commercial
Tile, ceramic
And so forth.
Ymmv.
I used to use a wheel, After getting my laser I realized how much I was constantly shorting myself by using the wheel. It just wasnt accurate enough. I bet I paid for my laser the first week I had it just by no longer shorting myself.
Goomer
Bronx, New York
Frank Mendo
Measuring distance is one thing.....Sending the data via BT to a device is another thing.
What your device can do with the imported data, and what it cannot, is the question.
Unless the measurement data can be seamlessly integrated with your invoicing app of choice, then you would still have to manually enter it from the measurer's proprietary app to your primary invoice app.
If it cannot, which it most likely, what would be the point of sending it via BT to any other device, if the source device already saves it?
Prob easier just to enter the data it to your invoicing device while looking at the measuring device log, instead of going back and forth between different apps on one device.
Russ T.
Slater, IA
Russ Terhaar
Bosch GLM 40 Laser Measure, 135 Feet https://www.amazon.com/dp/B00VI7WC32/ref=cm_sw_r_cp_api_ni38ybKQXAGWK
That's the one I have. I'm rarely out anywhere near 135 ft so you might save money by going with one with a shorter range.
Goomer is right to question whether the Bluetooth will translate to a meaningful difference in the field.
Service Monster on my iPad with the laser tool has been working great for a couple years now....
jwfoulk12
PA
Justin Foulk
Up to 100' gtfo...... I still love my Letica D2... it's not Bluetooth, but gives your the sf, total for the room and running total of everything you measured... We measure commercial jobs and 100' is so limited.. I think mine goes up to 197'..
This is the one I use as well. Love it. Its paid for itself 100 times over just in money that I was leaving on the carpet.
Reactions: Nate The Great
Heart of Dixie
Justin, that's great. However, I've never felt as if I accidentally left money, as I can adjust for shape and obstruction. No customer has ever questioned the numbers. On the other hand, as you guys do multiple homes a day, perhaps it saves time and effort.
I do wonder though; are these true laser measurements, or is the laser simply an aiming pointer for a sonic device? The latter has given me unreliable measurements many times (which is why I now use a wheel).
Times have a changed since the 1990's and sonic meters.... When I got my first Leica D2 is when Ken Snow told me about it... The price was $230 at the time... I thought I lost it so I had to buy another one after trying the Bosch one from Home Depot... That thing didn't compare... So my second one cost $179 I believe... Now I leave one in 1 van and the other at the shop, so if my pops or mom needs to measure a job, they don't have to dick around with the Stanley Tape... A wheel can still be off... My laser is accurate down to the 7/16" or there a bouts... You literally measure a whole house in less than 2 mins and get the total SF times your price add tax and wallah you've impressed your clients with up to date equipment...
http://www.ebay.com/itm/like/122406000789?lpid=82&chn=ps&ul_noapp=true
And it looks like the new models have Blue Tooth and goes up to 330'............ @Desk Jockey :winky:
PrimaDonna
Megatron
NorthEast, USA
MB
We have a disto. It is blue tooth but we don't sync up with anything. We just enter info in service monster. Mostly use in commercial situwtuins since we price by the room residentially. But we use it to verify if a room is over 250 sq ft since that is our cut off for a single room.
Very easy to use. Saves so much time and errors in manually calculating sq ft.
