Saiger's "Cide" Sauce Lime Citron Odor Destroyer is ready now!
It's ready!!! The New Saiger's "Cide"Sauce Lime Citron Odor Destroyer is in the jugs!
Available in 2 x 1 gallon packs or 4 x 1 gallon cases. Price is $34.99 per gallon! Not an odor cover but an odor destroyer! Tested on Horse, dog, cat urine... Even motor oil... Because that's what was in some of the carpet tested!
First batch ready. Webstore is live!
https://www.saigers.com/supplies/category/odor-removal
Saiger’s “Cide” Sauce Lime Citron Odor Destroyer
We started with a simple goal to develop a true odor eliminator that would leave behind a light pleasant scent and positive impact with our clients.
After extensive research, we’re excited to introduce Saiger’s “Cide” Sauce Lime Citron – the latest technology in odor destruction!
It absorbs, modifies, destroys and safely eliminates the worst odors from Urine, Vomit, Skunk Spray, Garbage, Must/Mildew, Smoke, Sewer backup, Organic decay, Cooking odors, and many more…
Pleasant odor elimination has finally arrived! Give it a try…your clients will thank you!
DIRECTIONSPrepare a solution of 8 oz. per gallon of water (1 part of Saiger’s Cide to 16 parts of water) and flood the contaminated area sufficiently to soak the surface where the odor may have migrated.Wait 10 minutes dwell time; if possible allow to dry before cleaning.If the cleaning will be done at the time of treatment, apply product to the dry carpet prior to any cleaning and re-moisten surface fibers with Saiger’s Cide after the cleaning.
General malodor of carpet, pet accidents:dilute up to 4 oz. per gallon of water and spray the surface evenly and allow to dry before using.
Pet bed, upholstery and mattresses treatment: dilute up to 6 oz. per gallon of water and spray mist the surface of fabric and brush gently and allow to dry before using.
General Cleaning solution: dilute up to 2 - 4 oz. of Saiger’s Cide per gallon of cleaning solution and proceed with normal cleaning to eliminate odors and freshen up areas.
ULV fogging: 4 oz. per gallon of water
A Great addition to Saiger’s Sauce 1 Free & Clear unscented!
Fragrance Boost to Pre-spray: Hydro Force Type Injection Sprayer – Dilute 2 to 8 ounces of Saiger’s Cide per 5 quart container with your Saiger’s Sauce Free and Clear (or prespray of your choice). It will give a very Fresh Lime scent with odor eliminating capabilities.
Pump up or Electric – Dilute 2-4 ounces per gallon of mixed cleaning Saiger’s Sauce 1 Free & Clear (or prespray of choice)
icleancarpetz
Rafael Samson
Is it better then that ineffective weak Jokercide by Joe?
Wandslinger
Tom Meyer
Say what you will, but man that stuff smells great. I've only used the little spray sample and the clients love that smell. I've only used it as a post squirt in a room.
