I used one of the worse wands ever today
$1200 to torture my employees so tempting! They love the Mach 15.
And look the swivel is getting more affordable.
Bob Pruitt
Robert Pruitt
I tried Chandler Thompson's new Devastator wand at MF St. Pete. and I didn't want to give it back. So now I have one too :-)
Don't think there are any plans for 1.5" . . .
Had a nice discussion with Tom . . .
Ever since I stopped using a 2 inch wand my my hand has stopped going numb, and my elbow and shoulder stopped bothering me.
I will never use a 2 inch again, It is to much wear on my body and not worth it to me.
You should see what I got coming.
And I agree with you..
Reactions: Todd Millar
KevinD
Kevin Dumas
I've said it for years. I think the first guy that develops a decent 1 3/4" tubed wand and gets a vacuum hose manufacturer to make 1 3/4" vacuum hose is going to hit the mother load.
Inch and three quarter with a flare on the end to two inch. Same as the stair tool. Prichem quad wand and prochem extended stair tool.
My bane was the same way.
Is that meant to be an endorsement?
I did like my bane wand but don't use it anymore.
And that stair tool is inch and a half flared to two. I just pulled it out for these stairs. It's a new tool to me. And it wasn't $600!
I tried going to that 1.5 tube PMF that Melon was hawking last year. I liked it, enjoyed using it, but in the end I had to put it away. The humidity down here is bad and my customers noticed the longer drying times.
It was embarrassing actually.
I have only gripped a 2 in wand and thought omg my arms will fall off if I used this daily.
But with a glide they may not be to bad. I'm willing to give it a try one day especially if it really helps dry times.
KevinD
Kevin Dumas
2 inch is king. You alternative types are all gay
Here is a quote from "2013"
You have flip flopped many times over the years on 1.5 versus 2.0
If you are young and in good physical condition, wrestling 2 inch hose all day won't be too hard on you. As you age, you will begin to as yourself what the point is?
I reached that age last year, at age 54.
I now use a 1.5 inch wand and whip.
I don't have a drying time problem, nor do my carpets look any less clean than they did when I was following the bulletin board culture.
I felt the same way when I was using my Mach12 wand. For the cheap price of a mach15, it's worth trying. I won't go back to 1.5" unless my joints tell me to
