Cavitation ??
steamron
Ron
Every so often my Prochem water pump will act up.
I will lose pressure with very little flow and you can see and gauge bounce up and down and hear the pump knocking.
General Pump calls it cavitation, my water box is full and I put a new hose on from the water box to the pump. They mentioned to check the inlet check valves, so I will try that.
Any suggestions?
Thanks
Check all your connections to make sure they are tight and no air can get in.
Could be a air leak in one of the fittings or hoses. Water box too hot? When I had a PC I would get that if the incoming water say from a water hose couldn't keep up. Incoming flow too high would cause my water box to over flow too.
Able 1
Keith
To test this, disconnect the hose going to your waste tank from your water box and lay it on the floor of your van.. If it doesn't open replace it. They usually get stuck open, but it is something to look at.. It should open at some point during your first job of the day..
One of those threads where will never quite know what happened!
But your welcome anyway!
Reactions: Able 1
steamron
Ron
I put on a new water box valve on in February, along with a new chemical pump diaphragm.
I replaced the hose from the water box to the water pump (some say that the hose breaks down over time and for a few bucks I put a new Parker hose on).
I'm seriously thinking it may be in the 3 way chemical control valve or a air leak some where around there. This morning I turned the unit on for the first job and it was doing it, so I shut it off and turned the 3 way valve to the off position. When I turned it back on it was fine, so I kept it off all day. But, it was drawing chemical because the rinse was down about 2 1/2 inches in the 5 gallon jug, when it was in the off position after doing 3 jobs.
This evening I replace the o-rings on the chemical check valve and double checked the water box screens. I turned it on and I have very strong priming, but with it in the on position the needle is bouncing around.
Reactions: SamIam and Able 1
Able 1
Keith
The water box to the pump NEEDS to be 3/4 hose..
The 3 way valve is leaking if you are drawing chemical.. Or the diaphragm is bad..
Start with the 3 way..
steamron
Ron
It is a Parker 3/4 inch,
Anyone know where to get a 3 way valve at a cheaper price then the over priced Prochem?
Mark Von*Lay
Mark
Last time I heard that term I was a young man in our magnificent Navy speaking the Kings English.
Able 1
Keith
