- Oct 6, 2006
- 117,273
Can you tell me what the pmf model # is of the trigger?Mine is 1000
You act like you're busyCall and ask Curt.
Its an internal design that I would have to take apart only to find out the number isn't stamped on it
What is the difference between this tool and a cobra hand tile cleaner?
The cobra can be a bit cumbersome and awkward to use in tight areas. If you need to flip it over or use side ways and trigger side ways, that cobra is a pain to use. It's like trying to grab a key and putting it into the ignition and starting up vehicle with an over size mit. Guess that's why it use to be free with the turbo force?What is the difference between this tool and a cobra hand tile cleaner?
Anyone know the product # of the pmf tool? I can't fine it on superior cleaning's website.
PMF U1590SB Grinder Hard Surface 4-1/2in Wide 500psi Internal Spray Specialty Hand Tools Scrubber Detailer Wand [U1590SB]
Not the same Raf
Mine is 1000
GREAT INFO. Thank you!Ten foot hideAhose
Two jets instead of one
No vac relief, worthless on this tool
Internal pressure hose
Better rubber grip
Higher pressure valve 800
How yours is 1,000 . I went to steam -brite website and I saw one at 500 psi. Do you customize yours?Mine is 1000
