FOJL
- Oct 7, 2006
- 18,851
- Name
- Lee Stockwell
Ouch
When you have the money, you don't have the time. When you have the time, you don't have the money. Binderedonedat.I know everything is taking awhile. I'm having money and Time issues. I'm doing the best I can with my limited resources.
Do you know how they say "Asshole" in my native language?Spanish?
Good thing these tanks are plastic. Can you imagine a hot drill bit in a metal tank.View attachment 72595 We were under time constraints to get up and running when we just got our new van. As a result, did the TM install myself.
Don't rush!!!!
I added a aftermarket mod "breather hole" to my new fuel tank.
No problem.I apologize to all my fans for not making a Bulkhead unboxing video. I've been working non stop and was just to tired. You can bet I'll make an install video.
I think you answered your own question. But the real reason is I wanted a partition wall with the ability to totally seal off the cab from the cargo area. Many times I'll bring my boys on jobs with me. There are times it would be nice if they could sit in the van and just play with their iPads while the van idles with the A/C running. I believe this partition will make that possible. I spent a couple of hours today installing it. I got to a point where I needed to go buy some special drill bits and hole saws. I'll finish it up tomorrow.Remind again why you want this?
Heat
Stench
Roll over
Consider yourself lucky if I get the lighting correct.Very disappointed. But redemption shall be restored during the installation video. It will be clean, crisp and generally ( with the most liberal of aspersions) to the point.
Tools needed will be present. No uncertainties. This vide is merely the final act of a well rehearsed dance done ad nausium.
It was. Plus it was 91 degrees that day, so it was hot. I'm glad to have that part done.Damn, that looks like a pita! Your going to love that your A/C actually does something, we roll around with the A/C cranked and the windows down.. The only reason I never put one in was because it will be harder to work on the machine(if you are planning to installing your TM tight against it)..
Who Dat?Your wife must have a good job, cuz you're starting to remind me of Ladwig
