- Oct 9, 2006
- 64,833
- Name
- Rico Suave
SHUT upppa!
Just joking. It looks like a "Goodfellas" piece of upholstery.
Ignore Chavez.
Before we proceed with your excellent upholstery cleaning adventure.
Will this in any way help?
My approach would be:Check out this tufted linen beauty........
View attachment 73050 View attachment 73051 View attachment 73052 View attachment 73053 View attachment 73054
https://www.restorationhardware.com/catalog/category/products.jsp?categoryId=cat1580034
https://www.restorationhardware.com...p?productId=prod4670041&categoryId=cat9790008
What's your approach?
No rusting of buttons.Ideal candidate for Von Schrader dry foam with TM extraction.
If Pemberton agrees with you
I'm gonna puke
Will you try to get here before he starts showing off next time?
Yeah, that's the ticket. A little gasoline and a match. If it melts or crumbles, problem solved, then they can call Chavez for the fire restoration.Frank, why not just do a burn test and see if it melts or crumbles?
If that's really solution dyed acrylic, your entire approach will change.
John, how do you know this isn't linen?
Chavez & Jim that agrees with Grasshopper: Just wondering about that:...........
After it dries if you still have water rings I might spray Yellow RX and rinse.
Steve Lawrence said: ↑
Because Goomer posted a photo of the info about the fabric.
Yes. Who is he Jimmy?Actually Jimmy came up with a very safe VLM cleaning technique that would address the smallish browning issue.
Kudos to a real professional!
