Removing TM,
steamron
Ron
I am going to take my Prochem Apex out to put in a new waste tank. I was wondering about how the fuel line is hooked up.
Any info would be nice.
Thanks
Jim Williams
Jim Williams
There is probably a hole drilled in the floor where the fuel line comes through. From there it should go to a fuel pump. I would take the clamps loose at the fuel pump. You may have to cut the line to get it off then put a plug in the line until you're done.
Able 1
Keith
There should be two hoses and two wires..
Able 1
Keith
Remember to take the two little hoses off your waste tank also.. And disconnect your waste tank float sensor.
