Anyone use this Solo sprayer?
Is it just me and mine or o they caps NOT like to be tightened down on these?
That long snout and adjustable tip are FANTASTIC for upholstery..
G
GreenTechAgain
Never seen one.
I do use the 2 gallon solo sprayers from Home Depot that used to be in the store. Can only get them from Homedepot.com now
D Luke
Derek
I use them and they are a great little sprayer. Best mist pattern I've found but they work best where low solution volume (relative to other hand sprayers) is needed.
No problem with the caps here.
Giorgio
Giorgio
Where are you guys finding solo sprayers? I've checked the big box stores and they only have the cheap throw aways.
I went thru so many of those i got fed up. Every few jobs seals would go. Since getting my multisprayer ive never carried them on the truck.
I've got a Penguin Gentoo.... I still find the 1-2 quart handy...... Mind Ya, I've got every size up to 5 gal.... I've even got a 5 gal. Hydro force set up on a cart...... Makes spraying large com. easy......
Dudes shouldn't blow off each other... At least not for free......:eekk:
Doug Payne would use a old portable for his sprayer on commercial jobs.. but I think you got everyone beat with a 5gallon HF.... :clap:
I've got several com. jobs that demand HWE, from 3500 sqft., up to 20-21,000...... Guys doing encap-bonnet all wrong..... They demand HWE.... Anywho, yeah, 5 gal. lasts a long time.....
We started using them in place of trigger sprayers a couple of years ago. Pretty reliable, if you don't store chemicals in them. Rinse after use and you won't have seal problems.
Reactions: Mike Pailliotet
Steve Lawrence
Ordered one to try but I'm not thrilled with the comments about these sprayers here and on Amazon. Seems they are kinda fragile but I do like the gentle mist for special care fabrics.
