- Oct 7, 2006
- 49,947
Not true.
Just pay attention the next time McDonalds runs out of chicken nuggets
Not true.
A porty, a Bane...Kenny shut up. You're telling them what an idiot you are.I use a Bane single cord with little giant portable heater. Still a pita!! My truckmount is a pita too !!! Don't think you know much about me being an idiot![]()
1/3 HP Ametek MotorThe Speedster/LTD vac mounts under the tank is the ideal configuration.
Being the tinkerer that you are, have you considered how feasible it would be to make some type of adapter kit to swap out the 5.7's vac motors to 6.6's motors on the newer Mtyee bodies?
John @ Mytee is working on it
I am confident that it would be a big hit with so many Mytee units out there.
Difficult to do for Series.
What's the flow on that pump?
1 GPM @ 400 PSI
Hp on the motor?
I know right!!!!At least I'm not defending them as the second coming. (Or third)A porty, a Bane...Kenny shut up. You're telling them what an idiot you are.![]()
Nuh uh, cause I'm not out doing residential, much less with a 3 cord party!!Prolly is
It's amazing what chimps will play with. I make each available in case one decides he really likes it and decides to go to town with it. Don't matter to me as long as I'm not using it, and I'm not!
1/3 HP Ametek Motor
That motor looks different from the other one used in your other Breeze.
What was the HP on the old one?
Looks like a nice little match for that cat pump, and lightweight.
"Difficult to do for Series."
Are you saying your proprietary motors used here are difficult for parallel, or all 6.6 motors?
The new vac motors were designed to run in series for maximum efficiency.
I taught him everything he knows....!
Now we know why Mrs Ladwig is desperate for attention.
Now I know why I built my own. If the pro's don't know how to do it, we are all in serious doo doo. Rick, parallel doesn't have to mean dual pipes. My parallel setup only uses one. Larry's setup isn't bad for series but loses suction and airflow due to the connecting hoses to the vac motors and waste tank. Whether series or parallel, put the motors on a permanent manifold and ditch the hoses. You will have better performance and it will take up less space@Goomer the vacs are High CFM low lift units. The other advantage to Series is only one pipe taking up space in the waste tank.
A series set heats up the rear vac motor a lot and doesn't perform that great past 50 feet. I would prefer two 8.4's in parallel. Hot temps cause hot wires and melted switches. If I'm only using 50 foot or less I'm not understanding the need for the 8.4's. I think a single 8.4 with a pump out would be a better option than the dual vac model if you are using 50 feet or under vac hose. If you are looking at hookups past 100 go with a parallel set up.@Goomer the vacs are High CFM low lift units. The other advantage to Series is only one pipe taking up space in the waste tank.
Yes, we are all well aware, as you have stated many times, that Airwatts is the best way to compare vac performance, but that does not warrant being a spec Nazi to all the seasoned porty deplorables that would like to independently chew on the cfm/lift specs for themselves.
Seems to be a old common practice to bury low cfm specs on machines with the vacs configured in series.
Larry, some free advice. If those motors are that powerful, put them in parallel. Mount them on a manifold, 2-2 inch holes, mount the manifold to the bottom of the waste tank with a single 2 inch standpipe. You will be blown away or maybe sucked into the machine. I did it, it works. I am only using 13.5 amp 5.7 motors and can run 150 ft hose lengths. Imagine what you can do.These are definitely high CFM vac motors (from specs 166 CFM; & 176" of lift measured)
The efficiency of these vac motors is so high that they run cooler & will last longer because of low temps.
The testing I have done shows excellent results for cleaning @ 25 ft.; or water extraction with 100 ft. of 2" hose.
AirWatts on this new motor is higher than two-stage 8.4" Ametek vac motor.
That is what is driving the higher performance.
The lift doesn't matter after you get to a certain point. The airflow is what will keep the lift effective over a longer length or using a bigger hose.The current Mytee speedster has two hi-perf 13.5amp 3-stage vacs mounted in parallel directly to the recovery tank bottom (no plumbing).
Very good performance.
This new machine beat it by 22% more lift @ wand when actually cleaning carpet.
Define efficiency.They were both 1/3 HP motors. The new one is more reliable.
Larry, invent an inline dry filter to use for vacuuming. For that matter, why would a devastator not work? Run the rotovac over everything dry, swap out the bag for a filter and storm on!
Imagine a Mikeysboard where nobody argued over vacuums...
