Living The Dream
- Oct 25, 2016
- 3,207
- Name
- Swani
I have been asked to clean some tile and grout without stripping off the sealer. Any suggestions on what to use?
Just use your carpet prespray with a ph of around 8-9. And get rid of that ***********. I've read a few horror stories about that stuffI have only talked to the owner and haven't seen the actual tile yet. But from what I'm told is that the home was built recently as a vacation home and hasn't had much use. They asked me to do the carpets and asked if I could do the tile while I'm there also but expressed that they really just wanted the tile to be cleaned and not resealed. I don't do much tile and grout but I have done some. I usually use my tile spinner and grout master which from my experience can be a mild stripper.
Thanks Matt! I'll see what I have for prespray around that ph.Just use your carpet prespray with a ph of around 8-9. And get rid of that ***********. I've read a few horror stories about that stuff
Great info! Thanks!Nick, in general you just use a neutral cleaner and a floor brush in such cases. Flush and extract the slops.
But: The sealer may be damaged from normal wear, the homeowner's use of strong detergents or the soils laid down over time. Cooking grease and spills can penetrate all the way through. The sealer may have been put down over uncleaned grout.
In short, emphasize that what you use will clean, but not damage the tile and grout. It won't fox any problems that are already there, either. It would be better to let you clean normally, and re-seal.
Thanks Matt! Always appreciate your input!It doesn't have any butyl in it, which is the key ingredient to stripping floors
Just mix it a little weak, and you should be ok
Listen to nate, and you'll end up being a peeping tomListening to Matty, you need your head examined...![]()
Hopefully I'll get to go look at the house next week. Then I'll have some more info.You probably need some more info. What kind of tile? Natural stone or Ceramic? I would clean normally and let them know that the cleaning may impact the sealer and that is their problem.
What PSI would you suggest?And use very low water pressure if you use your spinner. A lot of times the sealer will power wash right off of there.
Spinners need a certain amount of pressure to spin. Whatever works for your system, usually you need 400-700 minimum psi in my experience.What PSI would you suggest?
Thanks Steve! I'll do a little pretesting before I hit the job.Spinners need a certain amount of pressure to spin. Whatever works for your system, usually you need 400-700 minimum psi in my experience.
I bought a PMF hard surface wand and it works OK. Probably would want to do a small inconspicuous area first, what ever method you decide on.I've been meaning to get a hard surface wand
You sound like a bratI've tested every HS design wand on the market now and am left wanting more...
I liked the 2nd generation gekko brush head with the TM, not enough suction with a portable. The squeegee head locks down too easily. I have the 3rd generation gekko with the squeegee head and find the skirting to tough to get a good seal. A lot more maneuvering than what's necessary.I've tested every HS design wand on the market now and am left wanting more...
