Cleaning tile and grout only
Living The Dream
Cleaning Professional
Swani
I have been asked to clean some tile and grout without stripping off the sealer. Any suggestions on what to use?
does the customer know how long it's been since the grout has been sealed? And is the tile ceramic or is it a tile that has sealer on it as well?
Nick, in general you just use a neutral cleaner and a floor brush in such cases. Flush and extract the slops.
But: The sealer may be damaged from normal wear, the homeowner's use of strong detergents or the soils laid down over time. Cooking grease and spills can penetrate all the way through. The sealer may have been put down over uncleaned grout.
In short, emphasize that what you use will clean, but not damage the tile and grout. It won't fox any problems that are already there, either. It would be better to let you clean normally, and re-seal.
Living The Dream
Swani
I have only talked to the owner and haven't seen the actual tile yet. But from what I'm told is that the home was built recently as a vacation home and hasn't had much use. They asked me to do the carpets and asked if I could do the tile while I'm there also but expressed that they really just wanted the tile to be cleaned and not resealed. I don't do much tile and grout but I have done some. I usually use my tile spinner and grout master which from my experience can be a mild stripper.
Just use your carpet prespray with a ph of around 8-9. And get rid of that ***********. I've read a few horror stories about that stuff
Living The Dream
Swani
Great info! Thanks!
Would Saiger's Free and Clear be to harsh? I think it has a ph around 11?
It doesn't have any butyl in it, which is the key ingredient to stripping floors
Just mix it a little weak, and you should be ok
clean image
Carl Maddock
There should not be a coating sealer on tile
And grout installation. CPT.
HO definition of waht sealer is differs wildly
carpetcleaner
That is what I would do.
Without knowing what kind of sealer, when it was sealed or what has been used to clean the floor, there is not a way to know if there still is sealer on it.
You probably need some more info. What kind of tile? Natural stone or Ceramic? I would clean normally and let them know that the cleaning may impact the sealer and that is their problem.
Living The Dream
Swani
Hopefully I'll get to go look at the house next week. Then I'll have some more info.
Jim Williams
Jim Williams
And use very low water pressure if you use your spinner. A lot of times the sealer will power wash right off of there.
Jim Williams
Jim Williams
What PSI would you suggest?
What Steve said. I've been meaning to get a hard surface wand just for those occasions when I need a light sprinkle instead of massive pressure. Be careful. I have removed the sealer when I didn't want too. Nothing sucks more than having to strip and reseal a floor and not get paid for the extra labor.
Bob Pruitt
Robert Pruitt
I bought a PMF hard surface wand and it works OK. Probably would want to do a small inconspicuous area first, what ever method you decide on.
I would check the grout sealer before you start...a few drops of water...if it soaks in there isn't any sealer. Sell new sealer.
If you are talking about a color sealer- Then I would walk. But if they want you to clean it anyway...I get this regularly... after they sign release... then crb with white brushes if it's really dirty and rinse with Turbo...lower pressure than usual... or wand. Edge with wand and/or hand held Mikey Grinder tool.
I've tested every HS design wand on the market now and am left wanting more...
I liked the 2nd generation gekko brush head with the TM, not enough suction with a portable. The squeegee head locks down too easily. I have the 3rd generation gekko with the squeegee head and find the skirting to tough to get a good seal. A lot more maneuvering than what's necessary.
Jim Williams
Jim Williams
The little Gekko corner tool looks kind of cool for getting those edges. I may get the Gekko or PMF. The Gekko looks pretty versatile.
