Sunscreen
Welshmalc
Malcolm
customer with white sofa , turning yellow/ orange due to excessive sunscreen .No lables but looked like polyester ,customer thinks it's linen. Question. Is there a particular method for cleaning this.
Welshmalc
Malcolm
They sit on the sofa in there bikin . So a lot of the area is covered 30 % plus !
You need to find out what it is made of. Linen is a potential problem, polyester is safe to clean, but as an affinity for oily materials (like sunscreen), so you might need some different products.
Do you know how to do a burn test?
Reactions: Welshmalc
Welshmalc
Malcolm
Because the sofa just says made in China,I think it's more likely polyester.
Good. Just determine if it melts or crumbles. Because of how fabrics for upholstery are constructed, the details of color of flame, odor, etc are unreliable. You just need to know if its synthetic or if its made from a cellulose fiber.
Let me know, and I'll give you a formula and procedure suited to which one it is.
I wouldn't go that far. There is a lot of Asian fabrics made from cotton and rayon. Linen, I'm not so sure. But the consumer thinking its linen is not relevant. There are some fabrics where the "linen look" is printed on the fabric, and that print crocks off. Make sure you test for that too.
Reactions: Mike Pailliotet
Welshmalc
Malcolm
Customer phoned to tell me she's found a polyester made label receipt so the linen problems gone, then admitted she has tried cleaning it herself without success!. P
