Calling all Tile Experts/Pool Boys!
D Luke
MI
Derek
Got a call from a good residential customer today. Owns a health club that is going through a revamp. Tile/concrete in pool area looks terrible and needs to be cleaned up to hopefully "like new" for the re-opening.
Actual pool also needs to be cleaned/pressure washed due to construction soiling.
Would a strong acid cleaner (I currently stock Prochem Restoration Tile & Grout) easily do the trick on the tile & concrete?
I have a turbo hybrid and Cobra Hand tool at my disposal. If I need to reclaim water from pressure washing the pool any thoughts on throwing a water claw hooked up to a TM in a low spot? Any chemical limitations on what I'm assuming is epoxy coating in the pool? Care to point out any of the dozens of other factors I'm missing on a job like this?
I would be able to charge a fair rate but nothing exorbitant. Worth the hassle?
@Mikey P @scottw @Scott W @Jim Pemberton
Grand Rapids, MN
I bet some of that is permanent damage....
Just did a local YMCA pool this summer...similar situation even using acid, but we even saw the top layer of ceramic gone, and the concrete permantly damaged too from all the solutions in the pool
Reactions: D Luke
We have a manager of a health club with a shower room that pretty much looks just like that.
He calls every year before the franchise inspectors come out for their annual visit.
and every year we tell him the same thing.
Reactions: Mark Saiger
Why would you clean it with an acid? Isn't the ph of the tile already negative from all the chlorine? Unless you're talking about acid treating it after you do the normal alkaline prespray.
The only thing I would say MIGHT look better is the darkened areas from the oils of people's feet. Everything else is damaged from years of chlorine on it
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
I agree with those who say this will not clean-up great nor stay clean long term.
If the expectations are realistic (low), this si the process I would use:
  1. Clean with alkaline cleaner, Viper Venom Powder would be my choice
  2. Clean with an acid, Viper Renew would be good
  3. Rinse with plenty of water with a little alkaline detergent added to neutralize the acid.
  4. Coat the tile with a color enhancing sealer. This helps hide the wear.
With no reference to Matt's experience level, as I don't know him, this story and the veteran responses remind me of what I was once taught years ago by a crusty old man named Dan Petkovich who spent years in management at a local steel mill. At least I saw him as a crusty old man....I think he was ten years younger than I am now :eekk:
Dan used to tell me that in learning things, and life, there is a "dumb a$$" curve.
When you start learning a skill, you are a dumb a$$, because you don't know what you are doing. You are slow, careful not to make mistakes, and while you probably take too long at the task, your fear and uncertainty makes you sure to do the right thing, or to just not try it since you know you can't do it.
Then when you learn the techniques, and have some success, you get cocky, and when you get cocky, you make BIG mistakes by going beyond your ability, or you try to do the impossible. At that point, Dan told me, you are a dumb a$$ because you should have known better, but your pride and ego got the best of you.
Finally, after making enough mistakes, you wise up and you know the limitations of what you can do, and see no reason to try heroics that most often will lead to disaster, unhappy customers, endless "redos", and even expensive claims. You just refuse to do work that has little upside, and massive "downside" if it turns out badly.
At that point, Dan said, you are acting like a dumb a$$, but you are really finally a smart guy.
clean image
Orlando
Carl Maddock
Concrete need diamond hone/ refinish tile need a lot of manual crawling to remove hard water then clean
D Luke
MI
Derek
I will of course be passing unless they really want to pay me to use a TM and spinner on the construction dust as opposed to a mop and bucket themselves.
I use my truck mount on new construction a lot. It's a biotch to mop up drywall mud and dust. Hard to get it to not feel gritty to the touch.
D Luke
MI
Derek
@Tony Neville Do you agree with John? Easy-peasy?
Who makes Cal Clean? I'm assuming it's rtu which makes it really expensive. Definitely willing to give it a shot as long as the customer is willing to pay and they have realistic expectations.
Tony Neville
Columbia MO
Tony Neville
I think it's made by advanced. I hate to say no, so I would promise nothing and test an area.
Mop on cal clean with a cheap plastic mop(throw it away when done), let it dwell, scrub with a doodle bug and rinse. See what happens. Warning do not use in/on or near anything metal that you want to keep.
If they are looking at replacing it maybe you can be a hero. Managing the owners expectations is the key.
Reactions: J Scott W
D Luke
MI
Derek
Thanks for the info. It says it's safe for metal so surprised to hear you say otherwise.
Tony Neville
Columbia MO
Tony Neville
The first time we used it we applied it with a stainless steal pump up sprayer, by the end of the job it looked like a watering can. We blamed the chemical. It could have been that the sprayer was going to fail anyway but why risk it.
clean image
Orlando
Carl Maddock
All depends how busy you are. And how comfortable you are taking in unfamiliar work.
My spell check on earlier post had mind of its own
Those low spots on tile that pool and dry.
1. You want to remove most mechanically
2. Folllow up with cleaning using acid base and agitation.
If I remember cal clean is an acid. Phosphoric is another good acid for minerals
The hardest part will be the grout lines and mechanically removing most of it without scoring up the grout.
If try to go straight acid- you likely be unsuccessful and eating up all the good grout around it
There is possibility grout is stained - but will 90 percent better
Concrete is different situation
clean image
Orlando
Carl Maddock
I should note also, if you have a media blaster- will work well as well- problem will be containment unless you go dry ice
