How critical is it to park on level ground?
Cleaning at a house with a steep driveway. I don’t think the picture does the incline justice. How critical is it to be level? I realize oil levels and floats like a level area, but is it necessary?
You should see some of the walls that we have to deal with in the Santa Cruz mountains makes that silly little driveway look inverted
Did you get light headed in that house from the fumes?
I'd more concerned about the CO (carbon monoxide ) in the garage than running on the grade .....
This is so true it needs to be said more the once. Park on the street before you Kill yourelf, and maybe the customer, you knumbskull!! :dejection: :eekk:
Reactions: Total_Rookie
After a closer look, I'm would think you bottomed out on that driveway. hope you didn't damage anything important.
It all worked out okay. No bottoming. Taking the kids to the new Thor movie now. It was a good day. :)
Reactions: Bob Pruitt
And It sounds like it' getting even better.. enjoy the movie n popcorn.
I had one so steep a couple of weeks ago, the engine wouldn't run. The oil shut off float was shutting the engine down. Had to park on the street and run another 50 feet of hose.
WOW! that must have been one steep hill.!!
A
Able 1
I think I read somewhere that that max is a 35 degree angle, that is steep!!
Don't think it would matter much for a DD unit..
Reactions: Russ T. and Nomad74
Well, I took the wife and kids to see the Thor movie last night. All my wife talked about after it was how hot Thore was. I should have left her home. The magic of the fat Tom Cruise has faded.
Wheel chocks.
That reminds me. My pressure washer wants to turn in circles as it runs. It’s a 13 hp Honda motor. It can be run as low as 1200 psi, or cranked up, 5000...... @ 5k, a guy needs to use both hands. Buuut, it’s winter, and not something I have to worry about for another 4-5 months.
Outriggers?
