Ronald McDonald Scottsdale Auction #13- $300 PureForce Carpet Package
Up for grabs we have one 40# tub of PureForce Power Force Prespray and one tub of PureForce Clean & Soft Fiber Rinse
PureForce is a very popular new line of chemicals out of TSI Supply in Phoenix AZ. All the rage on FB these days.
Starting bid is $150 w/ 20 increments
Value is $300 and includes free shipping to the L48
Auction ends 11/7/17 @ 6PM PST
100% of the proceeds go to the Phoenix Ronald McDonald House
Payment must be by check sent to your's truly.
This formula incorporates a solvent into a blend of alkaline cleaning agents that quickly dissolves and emulsifies the heaviest of soil.
• Fast-acting high pH formula quickly dissolves the heaviest greasy soils
• For Restorative Cleaning of restaurants, apartments, and heavily soiled
• Super concentrated and economical to use
• Enzyme formula doesn't need extended dwell time
Directions:
1. Pretest for color stability.
2. Mix 2 oz. per gallon of hot water for pump-up sprayer.
3. For an Injection type sprayer, mix 10 oz. per 5 qt. container of hot water.
Shake well for complete mixing.
4. For heavy grease or oily soil, add 1-2 oz. of TSI CITRA BOOST.
5. Allow 5-10 minutes for dwell time. Do not allow to dry.
6. To neutralize alkalinity, rinse or post-spray with TSI ACID FIBER RINSE.
7. pH at use dilution 12.0-12.5.
CLEAN AND SOFT FIBER RINSE will neutralize all caustic residues and rinse away the detergents trapped deep in the carpet ber. CLEAN AND SOFT FIBER RINSE helps guard the carpet against re-soiling and to prevent browning after the carpets have been cleaned. Use this product when zero residue is desired. CLEAN AND SOFT FIBER RINSE is safe for 5th Generation Stain-Resistant Carpets. Formulated with anti-wicking agents.
1. Pretest for color fastness.
2. In a portable, mix 1 oz. of CLEAN AND SOFT FIBER RINSE with 5 gallons of water.
3. In a truckmount, mix 1 pint of CLEAN AND SOFT FIBER RINSE to 5 gallons of water to make a stock solution.
4. As a browning treatment, mix 4-6 oz. to 1 gallon of water.
5. As an after spray, mix 1 oz. per gallon.
6. A concentrated gallon of CLEAN AND SOFT FIBER RINSE will treat approximately 65,000 square feet.
7. pH in dilution is 3.5-4.0.
