We don’t need no stinking Propane!
Arizona
you not going to find a better unit than the 570's for the way they can produce and hold the heat......it's a bit hard to tame at times...but it can give you more then you will ever need...
I rarely use the 570 my tech does.
I’m on the pro 1200 mostly with a Devastator.
The video wasn’t a how to clean or look at my results or my bent handle.
It was only to show that it gets hot hot hot!
We only want to see videos on how to clean, or look at your results, or look at your bent handle.
Please try harder. :)
Since you have a 1200. What do you think about the noise? The ones I’ve heard are LOUD.
I think the prochem Everest is one of the quietest larger slide-ins I’ve ever heard. Much quieter than my 870.
Not any louder then a 570, I’ve never heard a complaint on it being to loud.
Like a el Diablo
Ron K
The side handle made me want to turn my head sideways. Lol
You should try it, it is more comfortable and is, I think better as far as arm position. It's a more natural movement.
Reaching for the handle parallel to the floor is not as comfortable, you don't have to turn your palm unnaturally with the assist at around1:40-2:40 oclock, it's more like a handshake.
Exactly.
I actually don’t offset the Devastator as per instructions of Tom.
But every other wand I own gets the twist.
Askal
Paulsen
Al
That didn't answer my question. What is your experience, or what are the truckmounts that you've owned that've given you problems?
CDs direct drive 450 and 470 hydramaster, Genesis and a few I don't remember. Always diverters and electronics. If my employees can't run and maintain a propane heater and an engine they are too stupid to clean carpet.
