Small Powerful Portable
jrizo1
looking for recommendations
I am interested on a Small portable that I can use for spotting, upholstery and small jobs
I have this particular restaurant that I clean ones a month but the main hallway get clean ones a week very dirty and will like to use a portable for cleaning the hallway weekly and I can use my truck mount when I clean all the carpet
I will like to use my existing wand and upholstery tool
wand is a devastator and the upholstery tool is a Sapphire Scientific Upholstery Pro
Thanks in advance
I'd invest in a 175 and a dozen bonnets. As weekly maintenance spray and buff can work well when you're doing corrective with HWE monthly.
You should be able to vacuum, spray and pad it faster than HWE. And it should also dry quicker.
Yep, and pixie dust!!
Ametek knows vac motors . . .
2" Flow in and out . . .
1500 hour brush life . . .
710 AirWatts . . . 170 CFM . . .
vacs schmacks
show me some honest solution recovery comparisons on a variety of carpets
easy as hell to do with a porty..cause it's easily accurately measured in and out
Reactions: SCC
jrizo1
I tried that but did not work way to greasy
Ed Valentine
Ed Valentine
I agree that Ametek produces the absolute best vacuum motors on this planet. But, Larry, that isn't the right 8.4 motor for this industry. Look beyond those numbers in actual usage. I am sure you could suggest another machine you sell instead?
Ed Valentine
Ed Valentine
Larry,
Respectfully, you can use most any vacuum motor for extraction purposes, however, IMHO
and testing, that particular motor is a terrific one especially for "Dry" vacuuming for several most important reasons. However, once again, you have made a good point, --it can be used--- in a carpet extractor. I guess it would all depend on what the Operator would be satisfied with as is the case with most any extractor.
However, I will agree with you that Ametek does make the absolute Best, period!
GeeeAus
Grant Baverstock
I think Domel make the besr vacuum motors...
There you go.
:rockon:
Reactions: SCC
