- Oct 7, 2006
- 3,232
- Name
- Jerry Cooper
Soooo yea, blower lift is fluctuating on a job to job basis.
One day I'll fire it up and my lift(hand over vac inlet) will go up to 14. Next job, it might only go up to 10, my vac relief won't even open at 10!!
I did replace my blower belts about a month ago, it's got to be a belt issue? Right? Somehow slipping? Should I keep tightening?! If I had to guess maybe a 1/4 - 3/8 or so, of play. Is that too much?
Blower already seems like it's higher on the bolts than before belt change. This normal?
I've replace my waste tank seal, no air leaks. Vac relief seems to be working fine, if I can get enough suck to open it!
Thanks fellas...
Thanks fellas...
