Two out of three teeth ain't bad..
Bruce
For $100 Mike will get his money's worth out of them , then when they are junk he can haul them off to the scrap yard for a few buck.
I found a good deal usually costs me to much time. Like installing then removing then doing it again in 6 months. I just hate it when I try to save money and costs me time and labor instead.
I'd look for a second hand store that sells used appliances. $100.00 cheap but....
We get some here now and then. I had a really nice glass top range and tried to give it to my daughter. The cleaned it up while I was in Az and it looked like new. She needed gas. :errf:
One of the guys said his mom's just went out and was willing to buy it for the labor put in it. I think Dan just gave it to him. Anyway the dork loaded it in the pickup and it few out on the highway to his mom's. Dented and busted beyond repair. :oldrolleyes: He should have just borrowed and van.
He was pissed because he had already told her and now he had to buy new. lol
Reactions: Kenny Hayes
Yep that has always been a hard lesson for me to learn too.
:errf:
I'm pretty cheap when its non-business stuff. I need to approach it at home as I do business.
We got a washer dryer stack from an apartment complex we work for. I got it for mom to move it into the kitchen from the basement so she doesn't have to go up and down the stairs.
She had electric but it was gas. We had the utilities installed for $850 into the kitchen where it would fit. I got the washer so I paid for the utility change over.
When we bought ours new we also moved them to the main floor. We kept the old ones in the basement for work stuff.
New door latch..
Omg, I’m just the opposite with some biz. stuff. I’ll pay $500 for an auto scrubber and go to Chicago to get it. But, when it comes to home appliances I want new or newer. Cars too.
Hoody
Steven Hoodlebrink
Years of Experience
20
Same set my grandma has. There is a filter in the washer just before the drain pump that will get lint and coins stuck in that needs cleaned 1-2 a year. It is in side the rubber hose that is square-ish shaped. Its a bit of a tight fit to get the two clamps off and may need pliers to compress the clamps to get them off and on. The door sensor often goes bad in them too but it is an easy fix. Good find, just watch those two things.
Reactions: Mike Pailliotet
Slow draining the symptom?
Hoody
Steven Hoodlebrink
Years of Experience
20
That or it doesn't completely spin out and you'll have sopping wet clothes/pads/whatever. When granny's was clogged, it would start to drain and then beep at us and stop.
